The shell is much wider right? Does anyone make a square taper bottom bracket that will suit? I have an old set of square taper cranks already hence the question!
I'll be building an on one fatty.
Any advice or help welcome. Thanks.
Phil Wood square taper 10mm BB is available. I have one with Middleburns and its a lovely made bit of kit. It is quite pricy but you can service it with just new sealed bearings, and if you have cranks then still cheaper than a full 100mm crankset. My PW has been great value lasting so long, and has only needed 3 sets of bearings in 5 1/2 years of beach riding.
Tim at Sideways should be able to help you out 🙂
What he said^ 8)
Charlie TBM has a Royce one in the works
you need a phil wood sq bb - great but not cheap
if you want a cheaper alternative
ive got a new howitzer bb with triple truativ chainset, only had 20 miles use
£75 posted the lot - good it you are going full gears on you rbuild
Im building an On One Fatty I have Race Face Fatty Chester chainset its an external BB retails at £120 (no Rings) looks ace can be run as a 1,2,3 ringsetup (frame depending) I cant comment on it as it arrived with the wrong bolt - hopefully it will arrive tomorrow so I use it at the Big Bike Bash at Avon Tyrrell this weekend
