Fabric Ti Railed sa...
Fabric Ti Railed saddle creak
[#12909655]
I have and had several Fabric ti railed saddles & after 18-24 months they all seam to start creaking. Anyone had the same problem?
Is there a cure other than buying another?
Posted : 30/07/2023 9:22 pm
I've had the non ti versions and they creak as well. A bit of spray grease every now and again up the side of the rails into the shell helps for a bit.
Most saddles do eventually if they have standard metal rails
Posted : 30/07/2023 9:24 pm
Some GT 85 sprayed into where the rails connect into the saddle. Reapply when necessary..
Posted : 30/07/2023 9:25 pm
My standard fabric saddle creaks as well. Went out on it yesterday and decided I couldn't ride with it any more so looking for a replacement
Posted : 30/07/2023 9:29 pm
I have a couple of Ti rail Scoops where the hull flex is part of why they're so comfy but the rail moves inside the areas where it locates. I tried oil and that worked for a while, cleaned it out then tried some latex solution worked into where the front of the rail fits and left for a couple of days to dry fully. That did the trick. There's movement still but it's no longer felt or heard.
Posted : 31/07/2023 8:11 am
