Exustar Look Keo Cl...
[Closed] Exustar Look Keo Cleats - black button thing ?
[#4751145]
[url= http://www.probikekit.com/uk/components/pedals-cleats/pedal-cleats/exustar-look-keo-cleats.html ]these ones[/url]
just putting a set of these on for using at the velodrome. Am used to Time cleats, so not used these before - what does the black button bit do ?
Posted : 14/01/2013 10:31 pm
Tiny bit of grip when walking.
Posted : 14/01/2013 10:38 pm
Posted : 14/01/2013 10:41 pm
IME fall out all the time just for sh*ts and giggles.
I may have this completely wrong but they are used when adjusting the cleat position, they sort of lock into place.
Posted : 14/01/2013 10:52 pm
Correct. You can drill a hole in your shoe, and put a screw in - black bit attaches to screw head. Remove cleat, leaving black bit behind. Install new cleats (minus black bit) - perfectly aligned cleats.
Posted : 14/01/2013 10:54 pm
I read a bit about them giving a 'memory' on the shoe when replacing the cleats, but that was for the original Look ones. I just whacked them onto the shoes (Spesh) using the guide lines anyway. Seems like the button makes some kind on imprint or similar, or stays there once cleat removed ?
Posted : 14/01/2013 10:55 pm
njee - thanks for that. So I assume if not drilling holes I just attach the cleat, with button in it's normal place attached to the cleat ?
Posted : 14/01/2013 10:56 pm
I believe they are there to stop the hard plastic pedal rattling against the hard plastic cleat.
Posted : 14/01/2013 11:05 pm
They are for saving your cleat position, genuine Look cleats have them too IIRC
Posted : 14/01/2013 11:59 pm
 Haze
Memory thing iirc.
Posted : 15/01/2013 12:19 am
Yep!
Posted : 15/01/2013 9:08 am
njee20 - many thanks
Posted : 15/01/2013 10:01 am
so if I take my cleats off how do I know what the position was?
Posted : 15/01/2013 10:37 am
