Exposure Joystick o...
[Closed] Exposure Joystick or Diablo? Quick, need one tonight...
[#3609682]
I get the output advantage but what about when using different settings?
Joystick gives 3h on high
Diablo 3h on medium
Considering the higher output of the Diablo, is 'medium' still superior to a Joystick on full burn?
Posted : 26/01/2012 10:40 am
Yes.
Posted : 26/01/2012 10:43 am
Thanks Muddyfunster. So in your opinion a better buy? or is a Joystick fine?
Posted : 26/01/2012 10:45 am
 br
but you can add a piggyback battery which doubles the joystick time, I guess similar impact on diablo
Either are good as a helmet light.
Posted : 26/01/2012 10:53 am
They have different beam patterns. Diablo has a wider spread, Joystick more of a spot. For a head torch I prefer the Joystick when matched with a bar light, but if it were my only light then I'd go for a Diablo.
Posted : 26/01/2012 10:54 am
I'm in need of a new helmet mounted light. I've got an older 225lmn joystick which is just not cutting it with a far more powerful bar mounted light.
I've played a lot with exposure lights but I'm struggling to quite see the point of the diablo. Great light and lovely and bright as it is on full power it lasts such a short time I can see myself rarely using the full beam mode much at all. Medium is a little brighter than full on a joystick but not by much. I can also notice a diablo on my head whilst the slightly lighter joystick is hardly noticable atall. Only a small difference mind.
I think I might hang around and wait for the trout "spider" when he launches it. A different league in terms of brightness but also a different league of faff with a tethered battery to deal with.
Posted : 26/01/2012 10:55 am
Light vs burn time (as per above), Diablo wins. Max light, Diablo wins.
Do you want to carry the extra weight? Joystick is super light and gives more than enough light.
Posted : 26/01/2012 10:56 am
I use both - Diablo as a bar light & joystick as a helmet light. The Diablo is like a flood basically so very good for lighting the trail in a general sense & its very bright. The joystick is much more of a spot & less bright but excellent as a helmet mount as the 'spot' is very useful for picking out detail when I turn my head.
ps I use a single-cell battery for the Diablo & flick between hi & medium.
Posted : 26/01/2012 10:59 am
Had a Joystick, now have a Diablo. Makes perfect sense to me, I turn it to full for downhills/fast & twisty bits otherwise it runs on medium (or low if pottering/stopped). Can't say I notice it any more on my head than I did the Joystick tbh.
Posted : 26/01/2012 11:08 am
Very informative blog from an ebay seller
[url= http://www.torchythebatteryboy.com/p/bike-light-database.html ]Here[/url]
Jas
Joystick on the Helmet.
MaxX D on the bars.
Perfect set up IMHO.
Posted : 26/01/2012 11:09 am
Or for flexibility get a joystick and a £35 white eye. Doubles lumens to 580 and still burns for 1.75 hours on full.
Posted : 26/01/2012 11:16 am
ask1974
Considering they are so close in cost, yeah I consider the diablo a better buy. On mid it still chucks out 600 odd lumens and is slightly more floody than the joystick meaning if it's your only light it's a bit more useful. Even on the low setting it'll get you where you need to go, plus you can add a piggy back battery or white eye to the diablo as well.
mrlebowski
Actually it's more of a spot, intended to be helmet mounted. A wider spot than a joystick, but quite narrow when compared with a maxx-d, six pack, vision 4 etc etc.
convert
Medium or low power for pottering about, full power for fast and twisty stuff. You'd be doing well to get half an hour of technical descent anywhere in the uk. When used like that you can easily get 4 hours out of it. I've not once had it run flat on me and have done 3 hours plus.
If you can discern the 20 grams difference between the joystick and the diablo maybe you could get a haircut and negate the difference?
Posted : 26/01/2012 11:26 am
Thanks guys, I think the Diablo pips it based on it's ability to run alone.
Cheers.
Posted : 26/01/2012 12:39 pm
That
