Exposure charger Q
[Closed] Exposure charger Q
[#437934]
Do they come apart? out tonight and it wont charge (no light at charger)
It has'nt played up at all until now.
Posted : 31/03/2009 12:40 pm
just had a quick flick through the instructions - all it says is to check that its plugged in and switched on (duh).
although if you have a charged piggyback cell, you can charge the light up from that.
it might just be the led in the charger has stopped working - see if it charges it anyway?
Posted : 31/03/2009 12:53 pm
No there's no charging light at the Joystick itself either.
Posted : 31/03/2009 12:57 pm
might sound stupid but you do have the switch at the wall turned on right?
and if you turn the light on without the charger in, does it work? (assuming you didnt run it dead last time you used it..)
Posted : 31/03/2009 12:58 pm
Still a bit of light left in it but not enough for tonight. There is no charge signal/light at the lamp unit or the charger.
My Niteflux is plugged in next to it....switches are on.
Posted : 31/03/2009 1:07 pm
not sure then, maybe you got some grit or something in the charger port last ride thats stopping it connecting properly?
even so, the chargers LED should come on when you plug it in, regardless of the joystick being connected or not - so I think your charger is probably bust.
Posted : 31/03/2009 1:10 pm
