Looking at cable clips like these-
https://www.amazon.co.uk/Sram-MTB-Housing-Hydraulic-Rotating/dp/B00AFPHGNO/ref=pd_cp_200_3?_encoding=UTF8&psc=1&refRID=4NFFVV87S2C36J2MDQ1Z
If anyone uses these or similar - can you push the cable into the clip through the open side or do I need to undo the cable and thread them on? I assume the former?
Cheers.
They just clip on.
Great. Hoping to use them to attach an external dropper post cable to a gear cable and be able to remove it easily.
im sorry, how much? wow.
Those do look pricy! I guess the articulation is a trick feature though. Obv, cable ties would do the trick but granted not everyone wants to look at cableties...
Get these on eBay a hell of a lot cheaper than that and more of them if I remember
ah, but are the ebay versions "Perfect for quieting the cross-line chatter at the cockpit junction"
or do they just stop cables being noisy?
or buy a roll of Velcro and wrap about 40mm around your cables.
Those come with reverbs for exactly the use your looking at.
Use them on all the bikes, great wee things. Mine are eBay ones though 😀
I got a couple with a Jagwire cable/hose set.
Got the same with a Reverb, found that most of them snapped quickly and ended up sliding up and down my cables for...well they are still there now
I just use small thin cable ties - cheaper and not prone to breaking.
