Does anyone know if it's possible to take the end supports out of an evoc bag to collapse it? They're a really tight fit and I doubt my ability to get them out again to store the bag under the bed.
Yes you should be able to, new bag comes with out them fitted, (yes they are a bit tight) so they can be removed, also the wheel tubes can be removed as well.
Wheel tubes I've had out but the end supports are hard enough to get in let alone out. Oh well, I'll try it when I need to and not before.
I found them really easy to remove...
Yup, just plastic rods, open Velcro flap & pull them out. Easy.
As the guys have said above, you just lift the Velcro flap and pull the flat bars our of the sleeves.
They are pretty tight but if you got them in there's no reason you won't get them out again.
