Evil Sovereign owne...
[Closed] Evil Sovereign owners?
[#2468652]
A few questions for ya.
I have built mine up SS using my Middleburn uno (square taper)and the non drive side is real close to the chain stays.
Pretty sure my bb is 68-73 with 113 axle.
Would a longer axle length cure it?
What dropouts are you all using I currently have it set up in the longer option.
What difference would it make to the ride if I used the shorter one?
Cheers Rob.
Posted : 14/02/2011 4:21 pm
113 axle should be fine. I run mine as 1x9 at present and never thought the chainring appeared too close to the chainstays. Should your bb have spacers?
Longer axle would be further away - this would also alter your chainline so may not work out.
I have rode mine with shorter and longer wheelbase and can't tell the difference. I think its just there to help ss setup.
Posted : 14/02/2011 4:55 pm
With the rear wheel shunted forward its manualtastic!
Run mine 1x10 as my general trail bike.
No issues re the chainstay crank gap.
Posted : 14/02/2011 5:25 pm
