Ever feel like you ...
[Closed] Ever feel like you don't have enough gears
[#9537533]
Clearly this guy has at some point.
120 gears!
http://www.ebay.co.uk/itm/RETRO-DAWES-EDGE-PRO-18-HARDTAIL-MOUNTAIN-BIKE-UNIQUE-120-GEARS-ULTIMATE-TOURER-/253102091852?hash=item3aee0f6e4c:g:cKEAAOSw-29ZSmnB&clk_rvr_id=1304637613638&rmvSB=true
Anyone else remember when you were a kid and the bike with the most gears was the best? 10 speed beaten by 15 speed beaten by 21 speed?
Maybe this guy remembers and built the ultimate top trump gears bike.
Posted : 08/09/2017 10:32 am
I thought tourers were supposed to be simple and reliable?
looks to have the same (if not slightly worse) range as a normally geared 3x tourer/mtb too...
Posted : 08/09/2017 10:51 am
So much awsome for so little money.
I approve.
Posted : 08/09/2017 11:05 am
4x3x10 = 120 (may of course be duplicates)
Yes that is indeed a possibility
Pointless
I wish I had a harder gear on the SS when I spin out on the flat
Posted : 08/09/2017 11:08 am
Purple ano and yellow crud, brake booster and rim's. So much going on for so little effect, I approve.
Posted : 08/09/2017 11:10 am
Some cargo trikes use setups like this - cassettes plus hub gears plus multiple chainrings.
Didn't Sheldon brown have some bikes set up like this?
Posted : 08/09/2017 11:15 am
I tried to look up that hub to calculate what the lower gear ratio would be. However all I can find for Shimano 3 speed hubs suggest that it has a ratio of greater than 1:1 in low gear, which would render the whole thing totally pointless.
Posted : 08/09/2017 11:22 am
Citron rims! Bloody hell.
Posted : 08/09/2017 11:23 am
That's hilarious 🙂
A Sturmey Archer three speed has 1:1 in the middle, with the other two being up/down a third. That would be more useful.
Posted : 08/09/2017 11:31 am
Nice idea!
Most of my bikes are single speed, I find them sufficient.
Posted : 08/09/2017 11:43 am
 Bez
"CUSTOM BUILT DEORE QUAD CHAINSET 26-32-36-44"
Because the standard 22-32-44 would have been rubbish, yeah?
Posted : 08/09/2017 11:49 am
[quote=miketually ]Some cargo trikes use setups like this - cassettes plus hub gears plus multiple chainrings.
That was my immediate thought - though he was an amateur with only 63 gears:
https://www.sheldonbrown.com/org/otb.html
Posted : 08/09/2017 11:50 am
1x10 and very rarely wish I had more gears except on very fast tarmac descents in which case that isn't really proper mountain biking
Posted : 08/09/2017 11:56 am
The ultimate just-in-case-of-failure gear setup?
Even if both the rear mech and the hub gear fail, you still have 4 ratios to choose from at the front!
Posted : 08/09/2017 12:02 pm
Where would one find purple ano cable ends.
Asking for a friend.
Posted : 08/09/2017 12:03 pm
I rode a recumbent yesterday that had 81 gears.
It was too much IMO. just massive overkill
FYI it was a standard 3x9 setup with a SRAM DD3 hub.
Posted : 08/09/2017 12:11 pm
how do you customise a chainset and mech to take a 4th chainring?
Posted : 08/09/2017 12:13 pm
If memory serves, Shimano made a 4 ring crankset in the mid 90's, though it was at the cheap end of their group sets.
Posted : 08/09/2017 12:26 pm
Yeah, a lad next door to me when I was a kid had one, 24speed 4x6.
We were proper jealous
Posted : 08/09/2017 12:29 pm
so near, yet so far:
rohloff x cassette x chainset x hammerschmidt
= 14 x 11 x 3 x 2 = 924 gears FTW
Posted : 08/09/2017 12:31 pm
Can you run hammerschmidt with a normal chainset? Or are we talking a 2 chain setup?
Or...
Rohloff x eagle cassette x pinion. 2352 gears. May have some overlap. Shifter locations may be interesting...
Posted : 08/09/2017 12:37 pm
Needs more retro direct.
Posted : 08/09/2017 1:56 pm
My dad has a recumbent trike with 81, useful for running a reasonably close block and getting the low end you need to winch it's ungainly bulk up hills (remembering you can't get out of the saddle and honk).
I seem to remember all 3 hub gears were lower than 1:1, but it was Sachs or SRAM. I will be sending him a link to that bike.
Posted : 08/09/2017 3:06 pm
That's not a mid-90s cheap chainset though, it's more modern than that. My first thought was a chainring bolted to to the outer ring using the chainguard fixing holes.
Posted : 08/09/2017 3:22 pm
4th chainring adapters
http://abundantadventures.com/quads.html
Posted : 08/09/2017 3:27 pm
and then what? standard mech with limit screw way out and an unindexed gearshifter?
Posted : 08/09/2017 3:30 pm
No.
Posted : 08/09/2017 6:30 pm
I love that there are people putting together builds like this though. 😀
Posted : 08/09/2017 6:37 pm
