Euro Brakes = Lever...
[Closed] Euro Brakes = Levers + Rose
[#8038176]
Does anyone know if you can buy the levers 'english style' for deore brakes from rose (have a discount to use)
https://www.rosebikes.co.uk/article/shimano-deore-br-t615-rear-wheel-disc-brake/aid:670600
· brake lever: BL-T615 right
· brake caliper: BR-T615 post mount
· cable length: 1700 mm (can be cut to length)
· brake hose: SM-BH59
These would be ideal but they list the lever as 'right' so presumably would need to buy a left and longer hose etc.
Failing that any idea where i can go for a sub £40 rear brake for a freeride bike ready to ride
Posted : 06/09/2016 8:08 am
Undo hoses, swap to other side, top up fluid.
Posted : 06/09/2016 8:13 am
And you don't usually have to top up the fluid...
Posted : 06/09/2016 8:14 am
Are deore brakes flip flop, like formula T1's in as much as they will work either side up, or is the clamp different?
Posted : 06/09/2016 8:22 am
[i]Are deore brakes flip flop[/i]
No, reservoir is on top.
Posted : 06/09/2016 8:23 am
So id need to buy a left hand lever with long hose, looks like they only do 'fronts' in 1m hose lengths...bugger.
>>> im off to the wtd ad's then to see what i can find
Posted : 06/09/2016 8:41 am
