ESI Silicon grips -...
[Closed] ESI Silicon grips - fitting tips?
[#3606675]
Do any of you have any advice on how to ease the fitting and removal of ESI silicon grips?
Thanks for your help.
Posted : 25/01/2012 1:05 pm
Just plain old water as per instructions.
Posted : 25/01/2012 1:14 pm
Window cleaner.
Posted : 25/01/2012 1:27 pm
Window cleaner here too. They were still a bit hard to get on the last few millimetres, but they been stuck solidly in place ever since.
Posted : 25/01/2012 1:29 pm
Thanks for your suggestions - I'll give the window cleaner idea a try.
Posted : 25/01/2012 2:54 pm
Air gun to remove them and window cleaner to fit them
Posted : 25/01/2012 2:57 pm
I used an airgun to fit them originally but I've found that water, window cleaner and any alcohol based solution work fine.
Posted : 25/01/2012 3:27 pm
I'll add hairspray to the list, simple to fit, easy to remove - just a bit of plastic under the grip and a quick squirt of hairspray and they pop off.
Posted : 25/01/2012 4:57 pm
