Love my esi foam grips, my only gripe is they are a pain to get on and off, is there any other foam grips out there that are easier ie lock on coller?
yup, [url= http://www.chainreactioncycles.com/ritchey-wcs-truegrip-ergo-locking-foam-grips-2013/rp-prod39259 ]ritchey ones[/url], they come on collars.
They wear out quite quick though (after all they are foam...) I'm about to experiment with getting basic foam grips over the tube and collars so they are then removable
realistically, how often are you taking them on and off?
There's a number of lock-on foams out there mostly made by Velo, the plastic collar inside means there's less foam depth so to me they feel a bit less comfy than non-lock on versions. Nothing major tho.
The ESIs are quite different to other foam grips - they call them silicone, and they are much 'squishier' than other foam grips, which generally feel much denser.
I changed my ESIs yesterday, quick spray of Windolene under the grip and they came straight off.
I'd suggest if you like the ESIs you'll be disappointed with most foam grips.
yep windolene works for mine and really easy to cut for grip shift
The Chunkys are a good thickness match for GS too.
^This. No comparison really, especially against lock-on foam grips.
Specialized SIP grip?
Think this was originally Northwind's suggestion.
For putting them on, line up a few zip ties in the grip and slide in onto the bar using the reduced friction from zip ties. Then just pull the ties out.
Taking them off I just use a quick spray of IPA. Never need to take them off now tho with shimano brakes and I spec shifter.
