English Cycle'...
[Closed] English Cycle's does it again....
[#3737442]
Dang... 😛 😯 😀
Posted : 04/03/2012 8:44 am
Toddlers should be banned from having marker pens
Posted : 04/03/2012 8:48 am
nuts.
Posted : 04/03/2012 8:49 am
apo'strophe's
FFS
Posted : 04/03/2012 9:07 am
Why?
Posted : 04/03/2012 9:08 am
Why?
because they can - its a show bike, built for NAHMBS, not sure if they have an owner/buyer for it.
Posted : 04/03/2012 9:10 am
I would buy that instantly if I had the money. I've [b][i]always[/b][/i] wanted that exact design (perhaps in a different colour). Makes me sad thinking about it.
Posted : 04/03/2012 9:18 am
That is mental. How do they do they run the belt drive on the outside of the dropout?
Posted : 04/03/2012 10:18 am
[quote=I_Ache said]That is mental. How do they do they run the belt drive on the outside of the dropout?
With a hub assembly where the belt engagement thingy is also outboard of the dropout presumably.
Posted : 04/03/2012 10:23 am
Is that the gentle thud of a UCI official fainting I can hear? 🙂
Posted : 04/03/2012 10:30 am
Pretty Cannondale that :O)
Posted : 04/03/2012 10:36 am
 MSP
Its grotesque, really its the ugliest bike I have ever seen, its worse than that very very ugly downhill bike that was posted the other day built by the colour blind idiot.
Posted : 04/03/2012 10:39 am
Niche for the sake of it.
But then, that's what these shows excel at. If 1% of the new ideas from these shows make it to the mainstream, why not give it a go!
Hell, even electric shifting began life as a show concept. But then, that's destined to fail, because TJ says so...... 🙂
Posted : 04/03/2012 10:43 am
MSP - Member
Its grotesque, really its the ugliest bike I have ever seen.
Are you sure?
Posted : 04/03/2012 10:44 am
More info at Rob's site
http://www.englishcycles.com/custombikes/project-right/
Posted : 04/03/2012 10:46 am
I'd say it's done it's job.
People are talking about it. 😉
Posted : 04/03/2012 10:50 am
More apo'strophe's!!
More importantly, how does it ride?
I like the appearance if not the colour.
Posted : 04/03/2012 10:54 am
 MSP
Arghhh yes Bregante, that is worse, truly hideous on a whole new level, now excuse me as I burn my eyes out with acid.
Just because you can, is not a reason that you should (especially for that drop bar thing, truly gopping)
Posted : 04/03/2012 11:49 am
Wow, that's uglier than a hatful of monkey's bums.
Posted : 04/03/2012 11:59 am
Allthepies like I said how do they do it. I sort of guessed that the drive had to be carried through the dropout I just can't figure out how.
Posted : 04/03/2012 12:37 pm
[quote=I_Ache said]Allthepies like I said how do they do it. I sort of guessed that the drive had to be carried through the dropout I just can't figure out how.
From the link I posted above:-
"I decided I wanted to keep the single chainstay as close to the center line of the bike as possible, which would also enable me to put the drive cog on the outside of the frame. And being a belt drive bike, this makes belt installation very easy (no frame split required!). The rear hub is custom designed – the shell and axle are one piece, which I machined myself, had anodised and then built the wheel. The bearings are press-fitted into the tube at the end of the chainstay – the axle slides through this, then the freewheel carrier is splined onto the end of the axle with a cap bolts in place to hold everything together. An eccentric bottom bracket allows for tensioning the belt."
Posted : 04/03/2012 12:43 pm
Probably the same way lotus did it 20 year ago
The peacock grove bike was way better however and I've been quite a fan of robs creativity at English for a long time
There' is however a lot of this doing stuff because we can shit going on at the moment .......
Posted : 04/03/2012 12:46 pm
