There must be some engineers on here who could knock some up surely! Just been looking at them, more precisely the park ones at about £115. theres nothing to it! surely there would be a few quid to be made for someone with access to tools. matey selling those headset tools on classifieds seems to be selling a few, so surely there will be a market!
Old set of forks? Or an old rear triangle for rears? If you don't/can't be arsed to get something made up.
would be handy if i still had a frame or forks with rim brake mounts! progress is good!
Roger Musson's Wheel Building Guide, [url= http://www.wheelpro.co.uk/wheelbuilding/book.php ]here[/url] shows how to make one in wood. Well worth the £9 for the book.
My wooden jig has served me well - built wheels that have lasted a season of WC DH racing!
Sometimes I even use spokes! 😉
A couple more photos and a few words here:
http://www.gravity-slaves.co.uk/?a=412
Break out the 2x4's and a saw and go for it. If you think that's roach, you should see my dishing tool!
I can knock one up for myself, thought someone may like to earn a few quid!
gravity-slave - roach is a small silver fish with red fins yes? cant see one of them!
can't you turn your bike upside down and stick a couple of zippies (or clamps etc) on the forks at the aprropriate point ????
Not really if your starting from scratch
i have an old frame with rim brake bosses if you are interested, £25 collected.
Here's a very nice one, very art-deco, although my preference is for white (makes sighting easier). Note how he has used hard wood for the jaws (as did gravity-slave above).
http://www.flickr.com/photos/questionmarke/4190843350/
I got one that I got the guys in work to make for me. All stainless steel, with a post that takes a dial-gauge. It makes the job very easy.
C
Old forks & zip ties?
I made one from some angle iron and held together with 2 length of studding, its adjustable for width, but I only use it for trueing.
I'll get some pics on for you, if I can remember how to do it.
Would be useful for the occasional bit of truing etc., but for building from scratch I'd sooner give the job to a decent LBS. I simply wouldn't have the time to become any good at it. Good sense of achievement though I can imagine.
I made this, it does what I want it to do.
[img] http://images.fotopic.net/?iid=ycphrv&outx=600&quality=70 [/img]
anyone know what the flat plate at the bottom is for?
Old frame or forks works for my uses.
Love this thread, just shows what you can bosh together out of old bits to make a perfecty functional tool with somewhat limited resources! Proper British garden shed engineering 8)
I had the luxury of a small machine shop to slap some bits of old scrap together to make mine, so its a kinda cheat, but its still made from recycled bits so a little less went to landfill and I have a perfectly good wheel trueing stand. The DTI gauge really makes things that bit easyer and faster too! Theres a second one normally fitted to the lower arm for the circumfrential adjustment but I made it quick release so I can leave the tyre on.
nice bit of scrap metal you there 🙂
I'm feeling inspired. I've always just put my wheel into the singlespeed (which has rim brakes) but the vertical bit has always been a bit haphazard. Might try something with a hinged bit doing for front and rear wheels.
Bump
Am planning to build a wheel jig, probably an adjustable one as per Mr Musson's wheelpro guide - just wondering if anyone has any bright ideas about non-standard axle wheels as I have a 20mm front and a 15mm front wheel in amongst the QR's. I have seen a cone thing that would work, centring the hole of the 15 or 20mm axle, with a standard axle on the other side, not sure where to buy them or how much they might cost to buy / make though, only saw an image on the t'interweb
I believe Roger Musson's book/stand covers 20mm wheels, etc. I haven't actually got round to buying it yet, but I did ask the question myself in the past!
Holding 20mm, 15mm and rear bolt thru hubs is easy in the [url=
Truing Stand[/url] <-- Click
RM
PS Book users : if you haven't already done so then logon to your new control panel for more of these sub-topics and detailed notes on the videos.
I've not got any pictures but mine was made from the legs off old school tables that were broken in the corner of the tech lab. Got me a GCSE and a young inventor of the year award (despite the fact that I repeatedly told them I didn't invent the wheel truing stand).
Thanks roger, the 20mm adapter looks pretty straightforward 🙂
+1 Rogers Mussons book. £9 and all the info you'll ever need to build wheels. No black magic engineering artistry or expensive kit needed, build a wheel perfect 1st time.
Nearly finished my wheel building stand from some scrap 18mm ply and plastic from a broken printer! Not going to be pretty as the ply edges are impossible to sand smooth without splintering but it'll work 100%.
