"Enduro" ...
[Closed] "Enduro" wheelz, wot's good?
[#8307113]
So, having done this to my 6 month old rear wheel I'm contemplating replacing the set (given the're both quite low end - intense hubs on sun rims)
If I do go down the replacement route, what's good these days (27.5)? Hope hoops have always served me well but seem relatively heavy in "enduro" flavour. Are the crank brother colbolts really not worth considering? Budget is £400 tops, riding is erm.. a bit of everything from Sherwood pines mince to DH mince (mince is the commonality but I'm quite heavy..)
Ta and hugs
Posted : 27/01/2017 12:16 am
Flow EX mk3 on pro4 evo hubs
Posted : 27/01/2017 12:20 am
^^ lighter than the hope hoops?
I had the original flows on pro11's for 6 years with no issues at all apart from a few dents ..
Posted : 27/01/2017 12:26 am
Hope Enduro rim = 510g
Mk3 Flow EX = 510g
So nothing in it weight wise.
Flow EX is much wider though
Posted : 27/01/2017 1:18 am
Loving my [url= http://spank-ind.com/spike-race28-wheelset.php ]Spank Spike Race 28[/url] wheelset. Coming from Stans Flow.
Posted : 27/01/2017 5:15 am
on the 25mm Flow EX MK2's here 2+ years on the rear, 18 months on the front. No dings or retensions needed (hand built by a pro) solid and a good weight. Riding selection probably similar
Posted : 27/01/2017 5:20 am
I(my lbs) just built up pro2 hope and mk3 flow rims. 30mm wide so need 2.4 tyres but they look great. Lbs said the rim quality is excellent and the seem very stiff and light. Just over budget maybe if you go pro 4 hubs.
Posted : 27/01/2017 6:21 am
 SOAP
Be careful with tyre pressure on the flow mk3. Flat spotted mine on the second ride. 🙁
Posted : 27/01/2017 7:28 am
The custom wheel builder on crc seems good value for hope pro 4 / stans builds (never used them like so dont know about the quality). I would definitely be looking at something on pro 4 hubs if I was in the market for wheels now
Posted : 27/01/2017 7:47 am
Hope Tech Enduro - similar to Mavic EN 521's - this clumsy sod has never damaged one
Posted : 27/01/2017 8:43 am
DT EX 471 or EX 511 on DT350 hubs, or EX1501s if you want a lighter set up.
Posted : 27/01/2017 8:53 am
Not sure you can get 471's on 350 hubs for £400, chain reaction are doing cheap crossmax XL's at the min.
Posted : 27/01/2017 9:08 am
I'm running ARC30s on Pro4s, brass nipples and DB spokes. from CR, came in at about £420 IIRC.
A year in and they're still running perfectly. I think they came in around 1800g or so when I weighed them, so not the lightest, but they've put up with a lot of abuse. I do only weigh 10st though.
TBH I would have got the Flow MK3s if they were available when I bought the wheels, but they weren't, and I have no regrets. Regularly running around 18PSI over rough and rooty stuff and there's no damage at all. However, I haven't pushed them on much rocky stuff.
They're just the right level of stiff for me as well - really nice in the corners but seem to have a smidge of lateral compliancy as well.
Posted : 27/01/2017 9:14 am
Thanks all, so... crank brothers idodine really worth avoiding?
Btw - has anyone ever seen such nipple failure as above? It was just a large stick through the spokes at low speed :-/
Posted : 27/01/2017 9:20 am
On the flipside I have - but this was at downhill centres and not quite 'enduro'
Second the notion on getting Pro4 hubs - they are superb.
Posted : 27/01/2017 9:25 am
Someone recently posted a link to the novatech hubs that are same as Superstar Switch on ebay. Very cheap - £45 a pair!! Anyway, these as they are fine and serviceable/replaceable parts + some LB rims. I have a few sets of rims, and have dented a ruined a few ally rims. The carbon ones are solid. Rock hard. They can really take a battering. Used racing in the Alps and UK riding and they havent been touched.
Thanks all, so... crank brothers... really worth avoiding?
Yes, you're the only person who keeps asking about them. Are they the only thing your LBS sell or something? The rule of thumb is never to a buy a crank brothers product with moving parts.
I'm enjoying my Flow mk3 rims (wide, light and unassuming), although similar to SOAP above - I was experimenting with silly low pressures (15 psi) and flat spotted on my 1st or 2nd ride. Might be worth getting some huck norris if you want see how low you can go.
and unless I'm mistaken (I can't find any evidence on tinterweb) the Flow EX [b]is[/b] the Flow Mk2. There is no Flow EX Mk3.
Posted : 27/01/2017 9:55 am
Crank brothers - cheap ish and light and look good.
I do need to think about dent resistance as have been known to dabble in DH with silly low pressures ..
Posted : 27/01/2017 10:05 am
 poah
ex471 on hope pro 4 for £420
https://www.moonglu.com/products/handbuilt-hope-pro-4-evo-on-dt-swiss-ex471-wheels
Posted : 27/01/2017 10:23 am
Hmmm interesting!
Out of interest - are Mavic Crossmax and similar a pita to find spares for?!
Posted : 27/01/2017 10:50 am
Did you just ask a question, then answer yourself?
I've had a set of Crank Bros Iodine on my Stumpy for a while now, they've lasted and genuinely seem quite stiff compared to most low spoke count wheels I've run. The spokes constantly make a twanging sound though as they re-tension and they're not very wide for what they pretend to be, I only use it for red/XC sort of riding and I can't say I'd trust them on anything more than that. Really can't see any reason to get them, aside from what they look like.
I considered putting them on my Enduro, but the stock OEM wheels were just as light, with miles wider rims.
Posted : 27/01/2017 11:22 am
/End thread as far as I'm concerned.
The only possible upgrade I'd be tempted by would be a wider EX 511 rim on the front.
If it's good enough for this guy....
[img] ?1468786055[/img]
Neil @ Moonglu's a damn good builder as well.
Posted : 27/01/2017 11:48 am
I'd add a tale of caution around Flow Mk3's too, I flat spotted both of mine in the first week of riding (it was in the Alps tho') and i've not flat spotted a rim in years. Pressure was no real difference from my ' normal' pressures.
Posted : 27/01/2017 11:59 am
Same as my on my Switchback - I paid £400 for them from a local-ish shop and have have been spot on for the past nine months or so. I run lowish pressures (20 front and 25 or so rear) and haven't had any issues with dinged rims etc.
The ARC rims are easy to set up tubeless and have held air like champs. They give the 2.3 minions a nice big profile (same as the 2.5's on my Demo).
Posted : 27/01/2017 12:23 pm
Personally those DTs on Pro 4s would be my choice, but it seems like you want to go lighter so perhaps something like American Classic Wide Lightnings are worth a look over Crank Bros and Mavic options?
Posted : 27/01/2017 12:34 pm
Are those Moon Glue wheels any good?
I'll be needed some new wheels on my Demo soon and the price looks good for my ideal hubs / rims.
Posted : 27/01/2017 12:51 pm
Any experience of Easton Heist wheels?
£280 on CRC at 1710g seems a bargain..
Posted : 27/01/2017 1:45 pm
 Sui
DT Swiss FR 570 on the newer version
[img]
put them on some Hope hubs as above.
As above, will finish a DH run with no tyres..
Posted : 27/01/2017 1:50 pm
if they're anything like any of the rest of the crank brothers kit I've tried the bearings will go within months, they'll fall apart and you'll be constantly re-building them (disclaimer - not used any of their kit for 5+ years due to consistently bad experiences, they may be better now)
as other have said, hope pro 4 on flow mk3 rims - got my last set built up for £350 by LBS. have 2 sets of flow mk3 rims, the oldest being 6 months and so far no issues - I'm a 15st untalented monkey on the bike who likes to ride fast but with little grace, running tubeless at fairly low pressures (20F,25R) riding on a lot of rock in the peak district
Posted : 27/01/2017 2:09 pm
The 'Gwin tyreless run' rim was an EX 471, not a FR 570, the EX is a much lighter Enduro/Trail jobbie, which is why it was such a big deal that it survived.
Posted : 27/01/2017 2:10 pm
Spank Oozys
Posted : 27/01/2017 2:12 pm
I've got EX471 on Hope for my new enduro wheels, still not ridden them unfortunately - but Gwin's aforementioned tyreless run suggests they'll be pretty durable.
Maybe risky going much lighter if you are a big unit?
Posted : 27/01/2017 2:17 pm
You could from actionsports.de
DT471 + DT350 + DT Comp + silver nipples = EU449
https://www.actionsports.de/en/dt-swiss-350-disc-is-custom-wheelset-mtb-650b-4138?c=397
I've got the 471's on SP 350 with Aerocomp spokes and they are brilliant.
Posted : 27/01/2017 2:18 pm
So Easton Hiest are they made of cheese! someone must be using them.
Posted : 27/01/2017 2:26 pm
I've got some Easton AR27's on the go and they are really good, no issues despite numerous overweight underskilled landings.... 😳
Posted : 27/01/2017 2:58 pm
Afaik Heists are ARC rims with a lower spoke count, making rim replacement a pain in the balls.
No idea about the hubs, but the above is enough to put me off.
Posted : 27/01/2017 3:16 pm
My ARC 30s have faired well for 18 months. Three mates have put multiple dings in theirs though. Mine have one small dent and still hold air perfectly and run true, I'm happy with them. I agree that a low spoke count probably wouldn't be ideal.
Posted : 27/01/2017 3:22 pm
I think that the Heist wheels use the ARC rims.
I've never had any issues with Easton hubs - my Havocs were fine for a few years. They were easy to service and easy to adapt the hubs.
Posted : 27/01/2017 3:27 pm
Not really, but they are a bit err... shit.
I've a set on my big bike and whilst they look flash they're out performed in every way by the Pro2 Evo/Lightbicycle carbon wheels on my hardtail.
Posted : 27/01/2017 3:29 pm
