I have got to send my shock to TF Tuneing today.. How do i get the "upper shock eye bolt cover" of on a Specialised FSR 2011 Enduro Comp?
is it threaded? is it pushed in? I really dont want to break it.
ANy help would be much appreciated. Cheers
Mine is threaded, once you start unbolting from the other side it comes loose
Could be that the weight of the rear end is compressing it all and pinching the bolt, take the weight off the rear wheel then try again
Got it, the bug "upper shock eye bolt cover" is on a rubber o'ring so pushes in and the bolt that goes through the shock was corroded thanks to some water so need a big hammer to persuade it out. Thanks schnor hanging my bike did help.
Cheers Guys
