End caps Dt Swiss
[Closed] End caps Dt Swiss
[#11455252]
I can’t find any 12 mm screw in for a 240 hub would someone on here be able to machine a 20 mm alloy bar with a 12mm hole or is this not right ?
Posted : 31/10/2020 3:09 pm
Front? No that wouldn't be right, 20mm is 110 spaced (but not boost).
Posted : 31/10/2020 3:51 pm
Yeah, I think you can't find it because it's not really a thing. Front goes 20mm, 15mm, 9mm, rear goes 12mm, 10mm. There's some weird nonstandards but really not many.
If you do have some mad nonstandard 12mm front then probably tophats in a 20mm adaptor set will work best, rather than a massive step-down axle. But I think to help we need to know what you've got
Posted : 31/10/2020 4:17 pm
Front , It would work the same as using a qr adapter that they do for a 135 mm they do a 15mm screw in end cap but I was looking for 12mm so I can use them on my gravel bike as well as my mtb
Posted : 31/10/2020 4:18 pm
It’s a 20mm at present was going to use it on a 15mm gravel fork but they changed the spacing to 12 mm which looking through Dt Swiss tech page they don’t do a screw in 12 mm ,they do a spacer for qr which is probably 5mm with a spindle as I have one of them . it’s a 240 s hub just didn’t want to part with the wheels
Posted : 31/10/2020 4:35 pm
The qr threaded end caps are just caps, no internal sleeve needed
15mm end caps with a 15od, 12id axle sleeve? Or machine the qr end caps to 12mm?
Posted : 31/10/2020 5:00 pm
I have 240 hubs (well, spline 1) with 12mm caps. They just push in, like the 15 or QR ones do. No idea where they came from - may have been on the wheels as OE
Somewhere deep in the DT website is a list of part numbers that may help you
Posted : 31/10/2020 5:08 pm
Here you go - not cheap, mind
https://www.ebay.co.uk/itm/312568413986
Posted : 31/10/2020 5:16 pm
I think I've got a few spares for DT Swiss wheels in the garage.
PM me exactly what you're after and I'll see if I've got he right ones.
Posted : 31/10/2020 5:22 pm
OP has threaded endcaps on a 240 OS hub. Push on won't work.
Posted : 31/10/2020 5:28 pm
I know they have to be screw on but it amazes me that they make them for the 350 hubs but not 240
Posted : 31/10/2020 6:16 pm
Ile look into that idea
Posted : 31/10/2020 6:47 pm
OP has threaded endcaps on a 240 OS hub. Push on won’t work.
I was wondering that as it wasn't stated but as has been mentioned the standard 240 endcaps are pushon.  I've got a 240 OS hub and had a hard enough job converting it from 20mm to 15mm. The screw on caps are a pain in the butt as they appear to be made of soft cheese.
Anyway, a quick google presents a potential solution...
https://www.campestralgear.com/products/dt-swiss-240-os-12mm-thru-axle-conversion-kit
Posted : 31/10/2020 7:19 pm
Thanks for the link I will read up on it 👍
Posted : 31/10/2020 7:50 pm
