Elixir 5 brakes...
[Closed] Elixir 5 brakes...
[#7115118]
I haven't used the bike on which they sit for almost a year, and the brake lever has become very stiff - it travels only a few mm before the brakes bite. There's no modulation left, obviously. How do I fix this? Will a bleed sort me out? I would expect the opposite problem (lever too soft), and I know how to fix that, but this baffles me somewhat. Is it because the brake fluid has absorbed water or something which increased its volume? Advice will be much appreciated - thanks!
Posted : 06/06/2015 11:29 pm
Piston seized? Buy Shimano.
Posted : 07/06/2015 3:59 am
A bad case of aviditis, get some shimanos 😉
Posted : 07/06/2015 7:45 am
Its only 3 bolts to get them off the bike.. Undo them all.
Posted : 07/06/2015 8:00 am
Probably a sticky piston. First would be to remove the wheel and try to push the caliper back in with a plastic tyre lever. If it moves then you may be ok or a bleed may help. If it doesn't then you will need to sort out the pistons which is a faff.
Posted : 07/06/2015 8:40 am
Yes it has absorbed water, even though its a sealed system. Quick fix is to let out a little fluid, but generally will need a full bleed. Longer term get rid of them, poor brakes. IMO
Posted : 07/06/2015 12:08 pm
I've the same. Been googling and found a fair few bits about the heat causing it. Tis hot today ??
Posted : 07/06/2015 1:43 pm
Had the same heat related issue on my son's Spesh Carve with elixir 3's.
So we could get out riding yesterday I had to bled off a little fluid as they front brake was locked on.
They still were not good. They fouled the disc despite repeated attempts to re-align the caliper etc.
When we stopped for a rest (even leaving the bike in the shade) they made a horrendous noise when we set off again and we ended up cutting the ride short.
A set of deore will be ordered on Monday.
Just a quick question. His set up is 180/160 (f and r) - can you use the same rotors or will there be an issue? I seem to recall that the 180 rotors from avid don't line up with shimano calipers or something? Is that right?
Hope you get yours sorted OP.
Posted : 07/06/2015 1:52 pm
Just ran cold water over mine for ages and its sorted it. It had been left in the back of my car all morning so was very warm.
Posted : 07/06/2015 2:34 pm
Normal man, just unbolt the brakes and fit using the old brackets. It should be fine.
Ashmonkey, that seems a sensible cure, its not like they ever get heat soak from long distance braking, is it ?
Did the Gorrick today with my Elixirs and I am not a lightweight. Have Uberbike floating rotors and organic pads today on mine and they worked fine, although I don't like them in the same way the shimanos work on my other bikes. Might get a cheap set of XT's from Merlins as have a 10% off voucher too ......
Posted : 07/06/2015 3:50 pm
Thanks for that. I'm binning them and will get some Shimanos. Not Deore though - the last OEM set I had also had a stuck piston. New SLX or XT if they're on a good deal seems the way forward. Will the Avid rotors work ok? I thought there was a small issue over size difference or something?
Posted : 07/06/2015 8:06 pm
Shimano don't recommend it but it will be fine, just make sure they're not 185 rotors with 180 adapters
Posted : 07/06/2015 8:27 pm
