Hi any advice appreciated.
Generally pleased with "feel" of the above. Cadence data acceptable, power reading consistant, (tested with vectors) known variation...so important things okay. But the speed/distance thing is more annoying than critical. I'm finding under load it's okay but during easy/recovery periods it goes up as high as 142mph. This is being recorded on a Garmin 510 using Ant +.
Evening bump 🙂
Not sure if this will help or not, but have you set the correct wheel dia? I have the same turbo as you but use the bluetooth conection & all the figures look about right for me.
I should add I am using the Virtualtraining app to record my sessions. The one that came with the trainer was really bad!
thanks for reply
I've stopped using mytraining app (elite) I use garmin connect/training peaks.
the speed records ok(ish) under load but flies up to stupid mph during easy intervals. I'll do the 12 click thing again and reset sensor
