Egg Beater maintena...
[Closed] Egg Beater maintenance
[#580077]
I have just noticed that the caps on my egg beaters have both come off. The body of the pedals are wobbling a bit too.
I am going on line to buy some of those metal caps. Re greasing them, is it simply a case of squirting grease in the pedal housing and replacing the cap. Or is there something more converlouted (spelling!) that I need to do?
skid
Posted : 26/05/2009 12:37 pm
Strip down and change of bearings is very easy. Sounds like the bushings have gone. All the bits you need comein one kit.
Posted : 26/05/2009 12:42 pm
probably better to get a rebuild kit, you get the end caps in it (did in mine for Mallets anyway) but if there is some play you possibly need to rebuild them anyway.
Not a massive job and the instructions are easy to follow, as are the videos on the website.
Damn mk1fan beat me by 3 seconds! Need to be more concise. 🙂
Posted : 26/05/2009 12:43 pm
'It boads well that speed impresses you'
Posted : 26/05/2009 12:57 pm
Some of the '03 onwards Eggbeaters come with a grease port which screws in the end cap threads and lets you inject fresh lube right through the pedal with a grease gun.
It will ensure every possible space oin the internals is packed with grease.
Posted : 26/05/2009 1:25 pm
