Edge 705 help
[Closed] Edge 705 help
[#2675159]
With the garmin Edge 705 how do you find the setting so you can get a grid reference for checking on a map? I dont mean the long/lat..?
Posted : 19/04/2011 12:40 pm
I dont think you can? someone said you can get long/lat but ive not found that on mine either.
Posted : 19/04/2011 12:45 pm
HHHHmmmm Im sure someone said that on the latest firmware you can..?
Posted : 19/04/2011 12:46 pm
Nothing mentioned on the update page at the Garmin website.
Posted : 19/04/2011 1:17 pm
Can't you just click on the map with the pointer - pretty sure that on my 605 it then shows the grid ref (and allows you to save it as a marker)
Posted : 19/04/2011 1:19 pm
settings > units > position format > British Grid
gives a 10 figure grid on the map
Posted : 19/04/2011 1:26 pm
Mrmichaelwright does that give you position on the standard maps?
Posted : 19/04/2011 5:35 pm
it does on mine 🙂
Posted : 19/04/2011 5:58 pm
don't quite get you.
on the map screen if you move the pointer it brings up a bit at the top giving BNG, distance/bearing from you and map info (road name etc)
don't think which maps you have matters, I have City Nav europe and outside BNG area it just shows -------
Posted : 19/04/2011 6:00 pm
