EBB position
[Closed] EBB position
[#5822127]
Needs some advice , which is the best position for am EBB , I'm going to be running gears, I'm guessing vertical, 12 o'clock or 6 position , my gut feeling is the 12 o'clock ,more pedal clearance, its a 29er so BB is usually lower. (Chumba HX2 hard tail).
Thanks 😀
Posted : 03/01/2014 11:23 pm
Whhhhhhhhhhyyyyyy? 😉
Lower is gooderer.
Posted : 03/01/2014 11:25 pm
Hi Mr K , I like lower 😀 BB height is 12.5" with 100mm fork, may run 120mm if I can find one....soooooooooooo where to start 😀
Frame specs http://www.chumbabikes.com/hx2-frames.shtml
Posted : 03/01/2014 11:32 pm
Or 7:45 from the drive side? Shorten those chainstays, steepen the seattube angle? 🙂
Posted : 04/01/2014 12:09 am
