eb camera software
[Closed] eb camera software
[#6497242]
Relevance of innovative solutions in the field of security and control had long been in doubt. For example , the creation of the enterprise integrated security system with video surveillance system provides a parallel reduction or complete cessation of theft of raw materials, equipment and finished products from the factory . All this together leads both to reduce costs and to increase productivity in the workplace . This allows in the near future to recoup the costs for the design, installation and maintenance of security systems and CCTV. Presence in videdomofone dedicated video memory or the ability to connect an additional unit with a similar memory significantly extends the capabilities of such a device . So you can create videoavtootvetchik that preserves a record with the image of the guest, depending on the settings on the host signal or automatically. Later, such images can be processed ( save , delete , view) depending on the need arises . If you want to video monitors were installed in several rooms at once ( handy if you want to move around the apartment is minimal ) , it is necessary to fix his attention on models with multiple monitors that operate in parallel. Their number can be up to four. If you doubt the intentions of his visitor , but have to admit it , it can provide additional security cameras, panels which will be installed under different viewing angles and prevent the emergence of intruders undetected. Image with these cameras is displayed alternately
http://www.pysoft.com/ActiveWebCamMainpage.htm
Posted : 20/09/2014 9:54 am
