Easton Haven Wheels
[Closed] Easton Haven Wheels
[#5609182]
Considering a set of these for my wife's bike
Big question is....
Can you change the axle type on the front? i.e QR to 15mm?
Posted : 16/10/2013 8:39 pm
On M1 hubs you can go from QR - 15mm , you can go from 15-QR and 20mm - 15mm.
you cant convert a 15mm or QR to 20mm. the 20mm hubs are larger in dimeter to accommodate the axle.
Posted : 16/10/2013 8:50 pm
Brilliant, thanks
Don't suppose you know about the rears?
Posted : 16/10/2013 8:53 pm
Rears it gets a bit more confusing and little more vague. Newer models of the hubs have push on end caps. these are convertible, however depending on what axle you have you will either need end caps and a new axle or just end caps.
If you have the older wheels with screw on end caps then you are stuck with what it comes with. If you are stuck then message me with what colour your axle is and i can advise from there.
Posted : 16/10/2013 9:51 pm
