Easiest way to put ...
[Closed] Easiest way to put photos on STW
[#5766464]
I've noticed some of you have put photos on as part of your post.... how do this??... I have used Flickr on my few successful ish attempts but that just puts a URL thing on....
Posted : 11/12/2013 10:07 pm
Using tinypic for example, upload photo and copy and paste the [img] link one.
Bobs ya uncle and fannys ya aunt.
Posted : 11/12/2013 10:12 pm
The forum help button has an explanation for Flickr, which I use every time. Basically you have to grab the BB code and paste that into the IMG tab
Posted : 11/12/2013 10:14 pm
The faq/help has a great guide you can use the Flickr BB code from the Flickr share button too.
Doesn't that just put the link in your post whereas I've seen actual pics on with the text ie bad crash guy.... Forgive me I'm shite but I do try
Posted : 11/12/2013 10:26 pm
No, trust us on this, we are Doctors
Posted : 11/12/2013 10:30 pm
Fairy magic innit
Posted : 11/12/2013 10:32 pm
1. Find an image you like, that is on the internet.
2. Right click on that image
3. Select 'properties'
4. This brings up the image properties (obvs...) in the middle of that box is what looks like a web address. Copy that, making sure it finishes with .jpg
5. Go to www.singletrackworld.com/forums and log in.
6. Find the relevant thread/start your own thread.
7. In the reply box, type [img] then paste what you just copied. After that type [\img]. Do not use spaces.
8. Click 'preview post' to check that it's worked. If no pic appears, go back to step 1.
9. If a pic appears (and it's the one you want), winner! You're almost there...
10. Click send post then sit back and await congratulation for your awesome pic. Go grab yourself a beer even, you've earned it, champ.
Fancy giving it a whirl?
Posted : 11/12/2013 11:03 pm
1. Click on the pic you want on Flickr
2. Click on the share icon at the bottom. (Little square with arrow sticking out)
3. Click on grab the HTML/BB code.
4. You will see HTML and BB code below the link. Make sure you click on the little circle next to BB code.
5. Now copy the link in the above box.
6. Return to STW and click on the IMG tab and paste the link into the window that opens up and press ok.
7. Preview post and pic should be there. If not give up. 🙂
Posted : 12/12/2013 8:17 am
Cheers people.....about time you saw some IOM pics ( without busted heads hopefully)
Posted : 12/12/2013 8:41 am
