Am I right in thinking that I can't adjust the trigger angles individually on this model? I'd like to bring the two triggers closer together as they're a bit "splayed" for my liking. I could adjust it on my old X0 but doesn't appear possible on this model?
dont think so
It is a rocker plate thing so the buttons just rock up or down, don't think you can adjust anything on them...I've seen GX and X01 and both seem to be the same controllers...
Think he means the old fashioned cable shifter, not the AXS controller.
Only the X01 or above shifter has a adjustable lower trigger:
[url= https://i.postimg.cc/G29F8yP4/339397.jp g" target="_blank">https://i.postimg.cc/G29F8yP4/339397.jp g"/> [/img][/url]
Yep, as ta11pau1 says, the adjustable lower trigger so I can bring the two closer together. Doesn't look like it's doable on this model so I'll have to get used to it!
