E8000 Cover/Panel
[Closed] E8000 Cover/Panel
[#11643379]
Evening guys,
I was out on my e-bike today and my E8000 motor took quite a nasty hit from a rock, its still working fine but the bottom of the motor is quite badly dented and scuffed.
Is there any options to replace this, I can see there is covers online but they are plastic so I presume replacing the outer casing is going to be a bigger job?
Its a bit dark to get a pic but I will attach one tomorrow.
Posted : 27/12/2020 10:07 pm
 StuE
If it's the motor casing then you are probably looking at a new motor depending on how bad it is,probably only an issue if water can get in
Posted : 27/12/2020 11:26 pm
rockguardz do protective covers to fit around/over motors which might be worth thinking about it?
Posted : 27/12/2020 11:38 pm
