E8000 Chainring
[Closed] E8000 Chainring
[#11730431]
Hi,
I have a Mondraker e-bike (2018) which has an E8000 motor on it, I am wanting to change the chainring on the front but not sure on exactly what is needed, can just the 'outer' ring be replaced or do I a direct mount style, here is a link to the two I am looking at:
https://www.wiggle.co.uk/shimano-sm-cre80-steps-chainring-fc-e8000e8050?utm_source=affiliate-window&utm_medium=affiliates&utm_campaign=Skimlinks&utm_term=Skimlinks&utm_content=Sub+Networks
https://www.e-bikeshop.co.uk/Shimano-Steps-E8000-Chain-Ring
Here is a pic of whats on the bike, sorry the quality is crap but its the only pic I have on my phone at the min!
https://ibb.co/7Kg5sNm
https://ibb.co/Rb96ZR6
Posted : 02/02/2021 12:37 pm
You can replace the chainring separately, as per your second link (or any other ring with the same bcd). It’s a bit of a faff to get the chain ring off without removing the spider, but possible as I managed it
Posted : 02/02/2021 12:43 pm
They use normal 104mm bcd chainrings, i.e. the most popular size.
Posted : 02/02/2021 1:31 pm
I just use 104bcd Snail rings for a tenner off ebay on mine, work as well as anything else. Not really a faff to change either
Posted : 02/02/2021 1:36 pm
Cheers guys, I tried getting advice from CRC and they mentioned i needed a CRE80-B chainring, 53mm?
Would any 104BCD ring work then?
Posted : 02/02/2021 1:49 pm
 StuE
Used an Hope chainring ring on my Esommet without any issues
Posted : 02/02/2021 3:44 pm
