E13 Lg1+ compatible...
[Closed] E13 Lg1+ compatible with SLX cranks
[#4469877]
I'm thinking of changing from my 2x9 setup to a 1x9 setup on my Nukeproof Mega. I'm using SLX double cranks (M665) and was planning on going for a 34T chainring with a E13 Lg1+ guide.
Does anyone know if the guide will fit ok without any modifications? For example, I don't want to grind off the granny ring bolts in case I ever want to swap back.
Thanks.
Posted : 18/10/2012 2:51 am
Works fine on my alpine 160, SLX cranks, LG1+ and 34t renthal chainring, no issues whatsoever.
Posted : 18/10/2012 6:52 am
Thanks for your reply. How do you rate the Rental chainring - is it lasting ok?
Posted : 18/10/2012 6:55 am
It hasn't had masses of use, but I see no reason why it wont last well. Only thing is it is thicker than other similar rings and I had to respace my chainguide.
Posted : 18/10/2012 7:37 am
Can also confirm it works 100% fine, use SLX cranks and renthal 34t ring too
Posted : 18/10/2012 8:35 am
I had to file mine down - not sure if they changed it on later models but my SLX cranks were the year of release. Without filing them it was impossible to get a decent chainline without the chain rubbing against the guides.
Posted : 18/10/2012 8:41 am
