So I need to change the BB on my E13 TRS cranks. The BB shell is a 73mm threaded shell, but I have no idea what BB I need...help please?!
Ta
What is the diameter of the spindle? I think it's 30mm?
If it is a 30mm spindle then google 30mm BSA bottom bracket. The bb I use for my e thirtneen cranks is from this link http://bor-germany.de/en/product/45-mtb-bearing-kit-bsa
The sealing is excellent so it should last a while. Hope also do one.
If it isn't 30mm then I'm not sure.
Hope this helps
Many thanks Edward 🙂 so if it's 30mm it's not a BB30 thingy then? That's the route I was going down...
FYI - it's very easy to pop bearings our on an E13 BB - just take the outer seals off, and tap them out from behind (leave the BB in the frame)
Might save you a few quid.
Thanks honourablegeorge, E13 BBs are not cheap and I'll need a new one this season. What bearings do I need though?
Mine took standard BB30 bearings.... was a while back though, maybe worth checking they haven't changed anything.
BB30 is a press fit bb whereas you have described a screw thread bb. Why there are so many standards of bb I'll never know!
Do any of you folk have problems with your cranks creaking or coming lose? I've got pre-APS LG1 cranks on my DH (2nd hand) dh bike and they keep coming lose. The only way to stop them working their way lose is to way over torque the crank which then obviously stops them spinning as the bearings are overloaded. I suspect the previous owner hasn't installed them correctly, but I'm not 100% sure what's wrong.
Cheers for the help guys. Identified the BB I need and they're out of stock everywhere, apparently Silverfish can't get hold of them to import any at the mo. Bit the bullet and bought a Hope one instead, never mind eh?!
