dx p7 wiring issue
[Closed] dx p7 wiring issue
 Pook
[#1306483]
Ok so the strip of metal from the cells to the fuse and circuit board rusted through. I've joined it up with some aluminium foil and it works fine. So I know what the issue is. Is it a good enough fix? If I tape it up will it work?
Should I not even risk it and solder it when I can borrow an iron?
Posted : 08/02/2010 10:23 pm
Do it properly and have a search for exploding li ions on youtube
you will see why .
Posted : 08/02/2010 10:36 pm
 Pook
No vested interest at all trout?
Posted : 08/02/2010 10:42 pm
no he just doesnt want to see you hospitalised
its in your best interest not to ride your bike with a bit of tinfoil making up a circuit
Posted : 08/02/2010 10:46 pm
Pook you asked for advice, you got it then made an uncalled for snide comment.
Bellend 🙄
Posted : 08/02/2010 10:48 pm
 Pook
Ok ok. I apologise trout. Perhaps it was a bit harsh. It was meant in jest. Cheers for the suggestion to solder.
However, the strip of metal is slim. About as slim as a fold of tin foil. what metal will the original strip be? And would an aluminium strip of some sort do the job? Maybe not foil but something similar?
Edit: don't think it warranted the last comment though.
Posted : 08/02/2010 10:53 pm
 Pook
Crikey.
Posted : 08/02/2010 11:14 pm
No Offence taken Pook it was as trail rat said .
I only had you best health at heart
you cant solder aluminium so it will be some very cheap recycled steel
there will be a lot of those tabs rusting away soon
Posted : 08/02/2010 11:34 pm
I bought 2 P7's from DX, one has been fine yet the other one was pish but next year i will be buying one from Mr trout 🙂
Posted : 08/02/2010 11:52 pm
 Pook
Right o- cheers trout. Much appreciated
Posted : 09/02/2010 8:38 am
