DX lights__buying a...
[Closed] DX lights__buying a spare battery pack
[#942489]
i know sorry its them damb lights again
does anybody know what i need to buy from deal extreme to make up a couple of extra battery packs (or can you buy them i just can't find them?) and maybe a some spare bulbs?
Posted : 11/10/2009 8:27 pm
You can't buy bulbs, and you won't need them, they are LED lights, where the LED is wired in as part of the light, LEDs should give a long life, and don't normally blow like bulbs do.
Don't know about the battery pack, sorry.
Innes
Posted : 11/10/2009 8:43 pm
http://www.geomangear.com/index.php?main_page=product_info&cPath=4_41&products_id=141&zenid=5glivi0emkn2m9hljml44o1ov6
you can get them from the above address from the US.
Posted : 11/10/2009 9:13 pm
can you not just buy the cables and batterys from dealextreme?
Posted : 11/10/2009 9:15 pm
you could buy from here http://www.turboferret.co.uk/ buy batteries off DX , you have to solder it up yourself but instructions are given.
just need a connector thingy .
Posted : 11/10/2009 9:52 pm
i can make a battery holder at work so its just a case of finding the correct batteries and conectors
Posted : 11/10/2009 9:55 pm
18650 protected are the batteries search on DX
Posted : 11/10/2009 10:09 pm
do you know which are the cables?
i'm not very technical
Posted : 11/10/2009 10:32 pm
 mboy
You're planning on using the light for more than 50,000 hours or so in total? 😉
Spare battery wise, they're just 18650 Li-ion cells, 4 of them wired in what looks like 2series 2 parallel... Speak to Turboferret. His website is listed somewhere above...
Posted : 11/10/2009 10:37 pm
i just thought may aswell get spares incase i fall off and break anything
and i'd like a couple of batteries , i also use my bike lights for dog walking and i take them when i go camping so a few batteries are handy
Posted : 11/10/2009 11:00 pm
pjt201 - Member
the problem with that is $40 + $27.50P+P =$67.50
which is nearly the same price as the complete light,
Posted : 12/10/2009 12:58 am
http://cgi.ebay.com/MagicShine-LED-Bike-Light-spare-replacement-Battery_W0QQitemZ280407769389QQcmdZViewItemQQptZCycling_Parts_Accessories?hash=item41499b012d
Think that will work with the bastid and cheaper than the one you suggest?
I've got a airbike sl2 and just ordered a bastid so hoping the batteries can be used interchangeably? If so then will probably order one of the above for 24hr races as a spare or could even buy one of those y lead things and hook up two batteries to one for extra long run time.
Posted : 26/10/2009 2:24 pm
You might just as well buy another set from DX then you'll have spare everything, surely by the time you add shipping from somewhere else just for a battery pack it will be the same anyway, and I think you're more likely to get customs poking their nose in with stuff from the USA?
Oh, and if you connect 2 batteries via a Y cable to one lamp aren't you doubling the voltage and risking something blowing, 1 battery (for eg.) gives 5 volts so 2 would give 10v ?? Correct me if I'm wrong ❓ I'm no electrician? ... Isn't there a laptop battery or something that would put out the correct voltage with a longer output that could be fitted with the correct fittings??
Posted : 26/10/2009 8:43 pm
Agree with the spares theory, just if your looking to do it cheaper that battery pack is about £31 instead of the £50 for the dx bike light. I wonder if anyone could shed light (ha) on the y cable situation?
http://cgi.ebay.com/Y-Cable-for-MagicShine-LED-Bike-Headlight_W0QQitemZ280413385105QQcmdZViewItemQQptZCycling_Parts_Accessories?hash=item4149f0b191
On further inspection it looks like its just to run 2 lights off one battery not the other way round but don't know enough to say either way if its possible to run 2 batteries to one light?
I hear smudge on here is the one to contact one on such matters. It would be interesting to see what sort of upgraded battery could be available for the bastid, airbike, magicshine etc???
Posted : 27/10/2009 10:49 am
Def might as well just get another light imo.
Posted : 27/10/2009 10:51 am
Instead has anybody found a replacement pcb for the battery pack? I used mine about three times then the protection pcb in the battery pack died.
It looks like it'll be quicker and easier to fix or replace it myself than sending it back to Dealextreme.
Posted : 12/02/2010 6:16 pm
