Dumb MTB Maintenanc...
[Closed] Dumb MTB Maintenance Question No.17635 - Removing the Crank Arm
[#1781871]
Mine takes an 8mm allen key, am I okay to remove it with just the allen key or is there some sort of ultra niche key I'll need too?
Am keen to avoid walking into Primera with a part disassembled bike and sheepishly asking them to sort it out for me.
Have watched the videos on 'Expert Villages', but they all seem to be a front for Park Tools/Pedros etc
Posted : 08/07/2010 3:49 pm
What kind of crank is it? I'd guess an 'older' sealed BB variety. If so, you'll need one of those Park/Pedros tools probably.
Posted : 08/07/2010 3:50 pm
what cranks are they? might be easier with a crank puller/extractor/whatever you want to call it!
It's a Truvativ Blaize 2.0 (Powerspline variant). 2010 bike, but not as to what sort of BB.
Posted : 08/07/2010 4:03 pm
You'll need a crank puller for isis cranks and maybe a spanner as well as your 8mm AK.
Posted : 08/07/2010 4:06 pm
Actually...might be able to get around it.
Cutting a long story short, I've broken my bash ring and want to fit a new one. If I just remove the driveside pedal and use a 5mm allen key to remove the current bash ring, is there even any need to remove the whole crank arm?
I apologise for the Play School nature of this question!
Posted : 08/07/2010 4:08 pm
I bodged this for a mate. I used the allen key and a Big nut which fitted into the outer cap : I drilled a hole bigger than the allen key in the nut then threaded the nut over the allen key and installed into the crank arm. Used a spanner to keep the nut stationary so the bolt in the crank arm undoes and pulls off the crank. if that makes sense? 😯
Posted : 08/07/2010 4:09 pm
OP - yes you can replace the bashring without removing the crank but it may be a PITA to hold the backs of teh bolts - there is a £3 tool if a screwdriver does not work.
Posted : 08/07/2010 4:11 pm
foxyrider - Member
I bodged this for a mate. I used the allen key and a Big nut which fitted into the outer cap - drilled a hole bigger than the allen key then threaded the nut over the allen key and installed into the crank arm. Used a spanner to keep the nut stationary so the bolt in the crank arm undoes and pulls off the crank. if that makes sense?
Just about!
Man, I hate going into bike shops unless in a purchasing capacity. I always get the feeling that everyone else in there can strip and reassemble a bike in pitch darkness.
Posted : 08/07/2010 4:15 pm
Cheers cynic_al. Will give this a go (or a bash!) after work.
Posted : 08/07/2010 4:17 pm
Eyes Closed actually Bravo 😉
Posted : 08/07/2010 4:18 pm
