When I do mine up tight it always seems to be in the wrong position. e.g. Horizontal instead of vertical. How do you get it to close going up?
Posted : 31/05/2010 5:44 pm
with the ordinary maxle you can build it up to be in two different positions 180 degrees apart. Other than that you are stuck with the angle it is at when you tighten it up
Posted : 31/05/2010 5:47 pm
So you can take it to pieces and swap it around. I will see if that makes a difference as there is a little bit of leeway. Cheers TJ
Posted : 31/05/2010 5:53 pm
mines always closed vertically, never thought why though..
Posted : 31/05/2010 5:55 pm
When I had a Wotan it would close in a ridiculous position. I did the 180 turn and it was ok. You'd think they could check that at the factory for what they charge.
Posted : 31/05/2010 5:58 pm
