Dull question: Wha...
[Closed] Dull question: What mudguards?
[#3703566]
For commuting, with 700c x 35 tyres on bike with full mounting points. preferably easy to remove should vanity demand it.
Posted : 22/02/2012 2:01 pm
SKS Chromoplastics. Once you fitted them, it's a 5 minute job to take them off again.
Posted : 22/02/2012 2:02 pm
 SiB
SKS Raceblade
Posted : 22/02/2012 2:03 pm
I'd have thought Raceblades might be a bit tight on 35mm tyres? Chromoplastics work well for me, good quality fixings and available in various widths to suit your tyres/frame. Not had to take them off, but it's all hex bolt attachments so should be easy enough to remove/refit.
Posted : 22/02/2012 2:18 pm
The Raceblade XL is designed for tyres up to 32mm only.
Posted : 22/02/2012 3:19 pm
Thanks. Chromoplastics it will be unless anyone has any views on [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=68581 ]SKS Longboards[/url]?
Posted : 22/02/2012 3:36 pm
Chromoplastics here too. Bit of a ballache to fit 1st time, but that's all in working out which fittings to use, setting up and adjusting the support arms. Once that's done, it's 3 bolts at the front and 4 at the back to remove/refit. They're pretty solid, not wobbly and not noisy. Lots of sizes available too.
Posted : 22/02/2012 3:42 pm
longboards look just the same only a bit longer
Posted : 22/02/2012 3:43 pm
Chromoplastics here too. Two pairs of them.
Doubt I'd ever have anything else.
or some nice chrome guards
http://www.gillesberthoud.fr/anglais/fiche_detaillee/fiche.php?refArticle=211INO704/CL
Posted : 22/02/2012 3:51 pm
+1 for Chromoplastics. I've got them on 4 bikes. Bombproof. You can even buy spare parts if needed.
Posted : 22/02/2012 3:56 pm
Yep they really are the best.
Posted : 22/02/2012 3:58 pm
