Dual Air Reba O rin...
[Closed] Dual Air Reba O ring size?
[#847529]
Hi, does anybody know the size of the O rings on the positive and negative air springs in 06- Rock Shox Reba Races?
I need to change mine as air is leaking between the two chambers and I don't want to spend £25 quid on a service kit when I just need two o rings.
Thanks for your help.
Posted : 07/09/2009 4:15 pm
The postive chamber has just one seal - the negative two. The kit comes with 2 "outside" of the pistons seals and 1 internal (between the piston and the shaft) for the negative chamber. You also get circlips and other bits.
As accurate as I can get with steel rule(from a new set waiting to fit):
o/s diameter - 27.5mm
i/s diameter - 21.5
Height 3.25mm
Let us know if you manage to source them.
Posted : 07/09/2009 4:28 pm
I've found some here http://www.altecweb.com/home.asp?cat=Subcategory8320a
they have some that measure 21.5 internal and 27.5 external but the cross section is only 3mm.
Has anyone here managed to use non rock shox o rings successfully?
Posted : 07/09/2009 8:37 pm
If they are made in the States, there is a good chance there imperial sizes.
I just tried to replace some in my revs, and found them to be inbetween sizes from the boxfull of metric ones that I have.
Do Lidl or Aldi sell O rings in boxes sometimes?
Posted : 07/09/2009 8:49 pm
