Centre lock rotor o...
[Closed] Centre lock rotor onto a 15mm DT240 Hub query...
[#1809720]
OK so how do I tighten a shimano centre lock rotor onto a 15mm DT240 front hub? I have the tool, it just doesn't fit between the lockring and the hub. I assume the axle comes out somehow...hammer?
Posted : 18/07/2010 8:16 am
Are you having trouble with your standard cassette removal tool? If so, it's because you often need a cl specific one which fits over hub axles.
Posted : 18/07/2010 8:20 am
To fit a centrelock rotor to a 15mm axle hub you use a lockring with notches on the outer edge and tighten it with the Hollowtech II BB installation tool.
Posted : 18/07/2010 9:17 am
Yeah, I know, I've got the lockring, I've got the tool - the tool however does not seem to fit between the hub and the lockring, think i need to remove part/all of the axle - what bit do I hit?
Posted : 18/07/2010 9:47 pm
Erm, nope, I've got the lockring that came with the shimano rotor...do I need one of these thingies?
Posted : 19/07/2010 8:37 pm
Dt 240 hubs with 15mm axles normally come with a lockring that is different to the normal shimano one, to acommodate the larger axle.
Posted : 19/07/2010 8:55 pm
