DT XMC130 TA fork -...
[Closed] DT XMC130 TA fork - 15mm or 20mm..?
[#412481]
The [url= http://www.dtswiss.com/Products/Suspension/DT-Swiss-Forks-(1)/XMC-Forks.aspx ]DT Swiss info [/url]on these forks seems to show conflicting information... the fork is listed as XMC130 15mm - but if you hover over the through axle logo above the photo of the fork it says 'generally 20mm in the front'! Seems a bit confusing.
Assume that they are indeed 15mm?!
Posted : 22/03/2009 7:30 pm
Might not help but just bought some XMC 130 and mine are QR!
Posted : 22/03/2009 7:33 pm
Options are standard QR or 15mm RWS which is a good lump more money. Unless of course you got a bargain from [url= http://www.wiggle.co.uk/p/cycle/7/DT_Swiss_XMC_Fork/5360036513/ ]Wiggle[/url] 😀 Just need Whyte to pull their finger out with my replacement frame so I can try them out.
Posted : 22/03/2009 7:51 pm
...Unless of course you got a bargain from Wiggle...
That's why I'm asking! 15mm it is then... 👿
Posted : 22/03/2009 7:54 pm
