DT Swiss Hub adapto...
[Closed] DT Swiss Hub adaptors XM1501 wheelsbspecifically
[#10558194]
Can non boost XM1501 wheels be converted to 110mm and 148mm boost?
I have been on the DT Swiss website and am still unclear as to whether this can or can't be done
Posted : 29/03/2019 5:27 pm
Depends on the year. If they are the lasted spline 30’s then you can get a rear wolf tooth kit to fit but the front is a different end cap size (by 2mm smaller if memory serves me) and non of the supplier make a kit to fit. You can use those horrible spacers from eBay but I hated those in the end I bought the same wheelset in boost!! I have the rear conversion kit somewhere.
If they are the older version then yes they can both be converted. I literally tried everything to the point I was going to get the older kit turned down by an engineering company but lost the plot with it
Posted : 29/03/2019 5:34 pm
These are what i'm looking to convert DT Swiss XM 1501 Spline ONE 25, if thta helps.
Posted : 29/03/2019 5:39 pm
You got the link to the exact model? It’s the front end cap flange that’s the problem. I suspect you have the newer model, but without a link/pic I can really help
Posted : 29/03/2019 8:32 pm
Your biggest hurdle is the center lock mount on the later gen wheels.
There is a company doing a larger splined cl adapter and end cap kit.
Posted : 29/03/2019 8:38 pm
Now8 is the company for the cl boost adapter
Posted : 29/03/2019 8:44 pm
Mine were not centre lock and the latest spec, so likely OEM. But they are out there!
Posted : 29/03/2019 10:06 pm
I have some XM1501 spline 30mm. The 6 bolt hubs are easier to to as you dont have to worry about spacing the centre lock mounts out. NOW8 make a kit for the rear wheel (generic) and you will have to put up with annoying spacers.
The trouble with the Spline hubs is they are not a 'stock' 240S hub, the end caps are slightly smaller externally. You can bodge the wolf tooth adapter to fit with a file but not ideal.
I got some end caps made up at work, basically gave the original caps & spec'd up the extra 10mm on the DS front cap, same as the wolf tooth adapter but in the right size, so I dont need to use a disk rotor spacer and identical rear spacers, just an extra 3mm on each side. I have to use a rotor spacer on this, but they are a solid press fit & all work fine. I cant tell the difference between these and my other XM wheeler which is boost.
Appreciate not everyone has the work facilities I do though, they would be a pain if I didn't have the ability to make up the end caps.
Posted : 29/03/2019 10:25 pm
The trouble with the Spline hubs is they are not a ‘stock’ 240S hub, the end caps are slightly smaller externally.
When you say 'smaller externally', what do you mean?
The only reason I ask is that I'm in the process of doing exactly this to my XM1501 spline 25mm (rear). I have this kit:
https://www.actionsports.de/en/boost-conversion-kit-dt-swiss-240s-dt-350-dt-370-is-rear-hub-12x148mm-22819
Popped the old end cap out this morning, pressed in the new one, seems fine, sits flush, is the right length in comparison with the old one.
EDIT: Were you just talking about the front? That is a weird size, had enough trouble converting from 20mm to 15mm.
Posted : 30/03/2019 12:04 pm
The annoying spacer option would not be to much of a problem as i very rarely remove the wheels.Do the spacer kits work with XD hubs?
Posted : 30/03/2019 1:56 pm
Yeah just the front on the newer wheels, they have a slightly smaller diameter of flange with the end cap and no one makes a kit. It’s only like 2mm smaller and the exact same size but it is smaller
Posted : 30/03/2019 2:02 pm
