DT Swiss EXP ratche...
[Closed] DT Swiss EXP ratchet compatibility
[#11826302]
Does anyone know if the revised EXP hubs are compatible with the older style non-exp ratchets?
Posted : 01/04/2021 6:19 pm
I have swapped freehubs between 240 exp and 350 without issue, it's not officially supported (there is an additional spacer over the bearing on a exp) but ran ok for me...
Posted : 01/04/2021 6:47 pm
Great stuff, thanks! I was pretty au fait with the old process for changing the ratchet, could you advise on how you did it? I see there's a washer in place of the second spring, and it appears the ratchet screws into something?
Posted : 01/04/2021 7:07 pm
Are you using an old one on an exp hub? The ratchet/ spring and red washer would need to be used. If the other way round both ratchets and springs.
Posted : 01/04/2021 7:30 pm
Ah the hubs themselves would have to be used with an ezp ratchet. The freehubs can be swapped...
Posted : 01/04/2021 7:31 pm
Ah ok. Thanks anyway
Posted : 02/04/2021 11:53 am
