DT Swiss 350 rearhu...
[Closed] DT Swiss 350 rearhub converters
[#8392202]
The hub is currently qr to convert to 142x12 shimano, is it a case of just changing the end caps (push fit?) or do you need to change the axle as well?
Thanks.
Posted : 09/03/2017 8:52 pm
Just end caps
Posted : 09/03/2017 9:38 pm
 LAT
It depends in the age of the hub. I have a 240 that predates 142x12 and a 350 post 142x12. The axle in the 350 accepts the 12mm axle, the pne in the 240 doesn't.
Posted : 09/03/2017 10:03 pm
So I can just pull out the end caps and measure the diameter of the hub axle to see if the 142x12s will fit in?
Posted : 09/03/2017 10:47 pm
I [i]think[/i] all 350s will have the more recent 12mm axle. But yes, easy to check.
Posted : 09/03/2017 10:50 pm
cool cheers.
Posted : 09/03/2017 11:03 pm
