DT Swiss 350 hubs c...
[Closed] DT Swiss 350 hubs convert to 20mm 110
[#9515343]
Hi all,
Got a 15mm dt 350 front hub. I've tried googling this and not for very far... can you convert them to go in a 110mm 20mm fork?
Posted : 25/08/2017 10:46 pm
https://www.wolftoothcomponents.com/products/boostinator
15 to 15 would be fine. 20 looks a bit trickier
Posted : 25/08/2017 11:02 pm
110mm isn't boost, it's just the normal 20mm standard (and why Boost is a complete bag of shite, while I'm on the subject). The 350s aren't officially convertible so unless there's a 3rd party route or a machining option you're out of luck.
It's literally the only thing the 350 sucks at, this. And it sucks at it very suckily.
Posted : 25/08/2017 11:24 pm
350 20mm hub is different, much thicker hub. I've got both 15 and 20 hubs, very different. There are options for 15mm, but 20mm is a dedicated hub.
Getting a 15mm hub and axle in a 20mm fork however... not sure, maybe there's a way of adapting the fork. Probably not practical from a strength / stability point of view.
Posted : 26/08/2017 12:02 am
Own a Fox 36- comes with 15 and 20mm axles.
Posted : 26/08/2017 12:13 am
Will this not work?
[url= https://www.acycles.co.uk/dt-swiss-mtb-front-thru-axle-conversion-kit-20x110mm-14829.html?gclid=EAIaIQobChMItaCy1q301QIVbLXtCh0KVQC4EAQYAyABEgLo5fD_BwE ]linkylinkthingmebob[/url]
Posted : 26/08/2017 8:19 am
Not on a 15mm 350 no.
Posted : 26/08/2017 8:32 am
