DT Swiss 240s / 350...
[Closed] DT Swiss 240s / 350 rear hub conversions - would like to double check
[#6430462]
Anyone know if it's possible to convert a DT Swiss 240s and 350 rear hub that is sold as a 142 x 12mm to 135 x traditional QR (5mm?)?
The online documentation suggest you can but I would like to double check before taking the plunge!
TIA
Posted : 21/08/2014 5:53 pm
You can defo convert a 240s, I've done it before. In fact I've just converted my other 240s to 12mm from QR.
Posted : 21/08/2014 6:46 pm
Yep, end caps just pull off. Be careful tho as the driveside cap on the rear hub also holds the freehub on, so just watch when you remove it!
Posted : 21/08/2014 7:09 pm
thanks guys
Posted : 21/08/2014 8:51 pm
