Hi guys.
So it appears that my front axle handle has broken off. The fork is the EXM 150 with 15mm axle.
The axle looks like this:
[IMG]
[/img]
The red bolt has sheared off along with a spring meaning that nothings holding the handle on.
I can pull the handle off and I can see the axle is splined which match up with the ones in the handle.
I can still undo it and tighten it up fine.
I dont think its integral to strenght? I think its just to undo it? Am I still good to use the axle?
Will I just have to carry the handle around for punctures and wheel removal?!
Thanks all.
I cant answer your question for definate but would imagine it'll be fine, as long as you dont lose the handle.
I had the 9mm version with the same handle, first one broke off within a year and I had it replaced under warranty, second one broke off 6 months later and I replaced the whole axle with a superstar one instead.
There's something inherently wrong with the design IMO and for £45 I'd expect better.
Same happened to me, just keep handle in your pack. Mines been like it for months and I've not had any issues
Handle is just a cheap plastic spanner really.
Cheers guys! Just been for a ride. All working nicely. Great forks actually!
