Dt rev spokes Q
[Closed] Dt rev spokes Q
[#1177540]
I have used rev's on a wheel build on my Campag hubs on my road bike and the rear wheel would keep going out of true, problem solved when I changed the drive side spokes to DT Comps.
So my question is are they up to use on my disc wheels on my s/s considering the hubs are zero dished??
Or would I be best sticking to DT Comps??
Ta in advance
Posted : 02/01/2010 10:24 pm
Revs are harder to build with because they wind up because they're so thin. Not inherently a problem but you need to be very careful destressing the wheel once it's built to make sure they're fully unwound. Strength-wise, they seem absolutely fine though.
Posted : 02/01/2010 10:29 pm
They're alright for raceday/skinny helium boned mincer builds (will be contrdicted by 16 stone freeriders who do 15ft to flat with no problem) but I'd stick to comps/supercomps tbh.Its only 61g difference.
Posted : 02/01/2010 10:30 pm
61g fair point the dust on my tyres weigh more
ok I was being a bit daft
perhaps Comps do make alot more sense less fuggin about
Posted : 02/01/2010 10:35 pm
I went with comps when faced with the same question on my wheels - not much weight saving given the potential problems with re truing
Posted : 02/01/2010 10:40 pm
Comps on the back, Revs on the front on my SS and have been no problems...
Posted : 02/01/2010 10:42 pm
Super comps are easy to work with and not much heavier than Revs.
Posted : 02/01/2010 10:43 pm
I'd have used Comps if I was building a wheel for someone of your "generous" proportions 😀 (only joking mate).
Posted : 02/01/2010 10:44 pm
Dibbs are you testing my "sensative side" 😐
you old bugger 😉
Posted : 02/01/2010 10:49 pm
