DT EX200 and Trance...
[Closed] DT EX200 and Trance X
[#4005555]
I want to replace my fox float R with DT EX200 but I'm in dead point now. I have no idea what size of bushes I should order for my frame? On CRC http://www.chainreactioncycles.com/Models.aspx?ModelID=16739 there are almost all sizes but which one I should choose? The main problem is with top eye because bottom must be empty to fit in trance frame.
Maybe you can help me 😉
Thanks in advance
Posted : 24/05/2012 3:07 pm
 anjs
Watch out the Trance X has a non standard sized shock as well 7.25" x 1.75"
Posted : 24/05/2012 3:12 pm
The trance X has a cut down 190x57. You cannot replicate this without having a shock custom made.
Posted : 24/05/2012 3:14 pm
I'd love to run a monarch plus on my trance, but bleh, the cost!
Posted : 24/05/2012 3:18 pm
I know trance has got 184/44 but I putted with succes float R 190x50 but now I wanna try DT Swiss. The only problem that bushing from fox doesn't fit DT that way I need help
Regards
Posted : 24/05/2012 3:40 pm
I think you're going to have to get the bushes machined down to get a DT shock to fit. CRC will have all reducers available, listed, as they/Hotline (who are CRC!) are the UK agent for DT.
Posted : 24/05/2012 3:52 pm
http://www.tftunedshox.com/MountKitGuide.aspx
I believe it is 22x6 you need, looks to be for sale here:
Are the bushings 1/2 inch (same as fox) ? If not, you are going to struggle with the bottom axle I think
Posted : 24/05/2012 5:19 pm
Isn't that going to **** your geometry?
Posted : 24/05/2012 5:23 pm
retro83 ---> thx ill check it
continuity --> no if you put 140mm front 😉
Posted : 24/05/2012 5:26 pm
