Anyone know if the freehub on a 350 spline hub will fit a 'normal' 350 hub and vice-versa?
Looking at some E1650 wheels but they have a SRAM freehub and was thinking of putting the Shimano one on my current 350 hub on them.
It _should_ do. The ratchet wheels all use the same freehubs, so as long as the 1650s use a ratchet freehub you should be fine. I say as long as they do as the 1650 is an OE only wheel, so I don't know if its a ratchet system or not, but if it is then you're good to go.
Thanks Ben. Yeah, I think the 1650 is a OE version of the E1700 (6 bolt v centrelock) with EX511 rims.
Yup, you'll need a different end cap as well though, DT do a conversion kit Madison code HBDT3745S.
You'll also need some of the red molykote special grease for the freehub splines, but if you're running a DT Ratchet you should have some of that anyway if you want to maintain it yourself.
I currently have Shimano freehub with 142 x 12 end caps. The wheels I'm looking at are SRAM freehub with 142 x 12 endcaps. Will I not just be able to swap freehub & endcaps over?
