Hello. Can someone help?
Does the freehub body for a DT 240 road hub fit the MTB version without any problems?
Thanks.
Posted : 09/04/2015 11:55 am
Depends, what spec hub is it and what spec hub is it going onto?
Axles, the kind of freehub it is (11-speed for instance) and spacing can affect compatibility.
If it's a standard 130/mm 8/9/10 speed freehub and both hubs are Q/R it should swap straight over but you may need a new spacer on the end depending on what's already on there.
Posted : 09/04/2015 12:19 pm
