My Paramo jacket is starting to guzzle water quite alarmingly, despite regular washing in soap liquid and reproofing with Techwash. The sleeves in particular are well-imbued with grime which a regular wash doesn't seem to shift. Does anyone have experience of getting Paramo or Analogy garments dry-cleaned and does it perk them up again?
I can't see dry-cleaning being massively effective. Better to wash it in a full-on biological detergent, then wash it with soap liquid so there's no residue, then reproof.
A lot of the dirt seems to be bike grease which I wouldn't expect a biological detergent to shift.
You don't reproof with Techwash - you wash with Techwash. Try reproofing with TX Direct Wash In - this is the stuff you should be using. If your jacket is really minging, do as chiefgrooveguru suggests - I've done this to my oldest Paramo (23 years old now) and it's still doing its job.
From Paramo webby
I have a stain on my garment what should I do?Prior to washing, try applying undiluted Nikwax Tech Wash directly to the stain - if this doesn't remove it then phone Páramo Customer Services for advice on 01892 786444. If it is a very stubborn stain, like oil, we would suggest a professional dry clean and re-proof which we can organise for you.
Yeah, sorry, I've been using TX Direct to reproof. Put "Techwash" due to morning brain.
Bimbler - Member
From Paramo webby
Looking at the website? That's almost as big an admission of failure as reading the manual!
