dropper seatpost on...
[Closed] dropper seatpost on Scott Genius
[#2585518]
I have a 2007 Genius, and am about to order a reverb for it, however im away from home at the mo, and cant measure my post.
Has anyone fitted one to a scott, if so was it the 380 or 420.
Ta
Posted : 21/03/2011 8:35 pm
Where are you ordering it from? Nobody seems to have them in stock...?
Posted : 21/03/2011 9:10 pm
evans have a few
Posted : 21/03/2011 10:04 pm
Hey did you ever fit the reverb if so how is it ? Or if anyone has fitted any dropper to a genius any advice would be appreciated, cheers
Posted : 12/03/2012 11:10 pm
You've not given us enough info, what frame size is it, how much seatpost do you run out the frame at 'proper'/fully up pedalling height?
IIRC Remember you'll be needing a seatpost shim for a scott as I think the frame is 34.9mm? I can't remember if seatpost shims are easier to find in 30.9-34.9, or 31.6-34.9
EDIT: Whoops, just noticed the post date of the OP ..
Posted : 13/03/2012 12:32 am
yes an old op but a current question, i have a med frame genius and run the post on the 4'' mark
Posted : 13/03/2012 12:45 pm
